Band symptoms/adjustment
Old Oct 7, 2019 | 05:17 PM
hidden1's Avatar
hidden1
Default Band symptoms/adjustment
What are the symptoms an or codes you will get when the bands are out of adjustment on a 3.9 01 dakota automatic.
I know theres front an back bands.
Thanks
Old Oct 7, 2019 | 06:51 PM
Delayed gear engagement. Won't set any codes though.
Old Oct 7, 2019 | 07:48 PM
hidden1's Avatar
hidden1
How can you distinguish bands needing adjustment vs major tranny problem .?
By the type of hesitation/jerk?
Thanks
Old Oct 7, 2019 | 08:58 PM
What year/engine/trans we talking about here?
Old Oct 7, 2019 | 10:02 PM
hidden1's Avatar
hidden1
It's a 2000 an 4 wheel drive.Ill have to check on type tranny..
Old Oct 9, 2019 | 06:57 PM
hidden1's Avatar
hidden1
What symptoms do you get if it's a shift solonoid? Hesitation on the shift?
Old Oct 9, 2019 | 07:25 PM
Need to know what engine and trans. Lots of different possibilities there.
Old Oct 11, 2019 | 11:37 AM
hidden1's Avatar
hidden1
From vin it says it's a 42re 4wd.
Has code 1795 an 0753.
Is this common issue on these with 3to4th shift solonoid an circuit to it?
Old Oct 11, 2019 | 11:41 AM
hidden1's Avatar
hidden1
Has 3.9 an is 4wd
Will the 3rd-4th shift codes mess it up if driven? 0753
Is this a common thing on these- with wiring code 1765 too?
which of the 3 would it be in the pic?
