Crank no start after wiring harness plug replaced
Old Nov 11, 2019 | 09:43 AM
professorbob's Avatar
professorbob
Default Crank no start after wiring harness plug replaced
I after soldering the new three wire harness connector to the cam sensor leads, got the color coding reversed on the outside wires of a three wire connector. The truck cranks but will now not start.
Trying to determine the damage caused: Sensor burned out or PCM fried or both? Any suggestions.
Prior had the intermittant cam crank signal.
After now have 0340 code.
Old Nov 12, 2019 | 10:22 AM
hidden1's Avatar
hidden1
Have you tested the wiring for the pcm signal an volts going to the sensor ?
