Poor running 01 4.7l qc
Old Nov 17, 2019 | 07:59 PM
angrysmileyface's Avatar
angrysmileyface
Default Poor running 01 4.7l qc
So I finally have it back together after replacing the harness. However I'm left with p0201,3, and 8 codes. The truck will try and idle on its own but eventually just stalls out. The engine makes the best effort it can but eventually just dies. Will replacing the injectors solve the problem or is there more I should be looking for?
Old Nov 18, 2019 | 07:42 AM
Think I would ohm check the injectors first, and verify the wiring.
Old Nov 18, 2019 | 07:05 PM
angrysmileyface
Will do. I have a couple I got out of an engine at the yard and see how they compare (yard ones were around 12.6 ohm) I will have to see about obtaining a noid light kit.
Old Nov 23, 2019 | 12:09 PM
angrysmileyface
Ones currently in the engine seem to be at 12.3 ohms. Tried getting a noid light kit but the az one was missing the light I needed
Old Nov 23, 2019 | 05:44 PM
angrysmileyface
So i pulled plugs on a whim and found an eclectic mess of champions and autolites at least in the first 6
File Type: jpg
Old Nov 28, 2019 | 10:58 AM
angrysmileyface
Plug change didn't improve my problem still wondering what else could cause it. Thought I heard rattling clattering on the passenger side. So I opened the valve cover there to check for messed up lifters, well I found this yucky thing instead
File Type: jpg
