2.5 Boosted?
Old Nov 20, 2019 | 04:47 AM
acesofwar's Avatar
acesofwar
Lightbulb 2.5 Boosted?
Let's say you have a mint stock 2.5 from 1998 and you wanted to throw a turbo at it. Where would you start/how would you approach it? Could you walk me through the steps?
With stock internals, how much boost could it handle?
Preliminary thank you!
Old Nov 20, 2019 | 08:17 AM
Generally, a motor in good shape can tolerate 5 to 7 psi boost. Of course, that assumes that you have all the supporting hardware necessary as well. You will need a 2 or 3 bar map sensor, and a custom tune for the pcm, so that it understand the sensor, and boost. May need larger injectors..... and don't forget all the plumbing on the exhaust side..... It's doable, but, not inexpensive.
Old Nov 20, 2019 | 09:30 AM
98DAKAZ's Avatar
98DAKAZ
The 2.5 is a jeep engine try this
https://www.google.com/search?biw=11...CZU4ChDh1QMICw
I don't think these kits are available anymore and not worth it
Old Nov 21, 2019 | 06:28 AM
rebeltaz83's Avatar
rebeltaz83
I had the same idea in highschool with my 87 Dakota 2.2. I was gonna Rob everything off a 2.5 turbo caravan and make it work. But I never got past the thought of it, lol.
