Defrost Issue
Old Jan 5, 2020 | 12:25 PM
Mitch Ridinger's Avatar
Mitch Ridinger
Default Defrost Issue
So I'm having an issue with my truck where the air is stuck on the defrost. One morning I found a strange piece on my floor on the drivers side which now I believe to be I guess you would call it a horn for the actuator you speak of under the steering wheel. So that one I believe is the defrost actuator.
Old Jan 6, 2020 | 06:27 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum Mitch. I moved this into a new thread.
What year is your truck? '01 and up are electrically actuated. Earlier years are vacuum operated.
As to that piece you found, you're probably going to have to check a boneyard. Many small parts are now discontinued.
Old Jan 29, 2020 | 12:15 AM
cheddarlaw's Avatar
cheddarlaw
also check ebay for small parts. I have found numerous discontinued parts there.
