PO203 COde trouble shooting
Old Apr 19, 2020 | 04:45 PM
professorbob's Avatar
professorbob
Default PO203 COde trouble shooting
Hello,
I am getting a P0203 misfire code. Questions: ! Others have said the the voltage should be 12Volts at the injector connector. Is this using the two wires ast - and + across the lead, or is this 12 volts from the positive wire to ground. If it is not 12 volts, what is the correct voltage. From a single terminal to ground. Thanks,
Old Apr 23, 2020 | 02:17 PM
00DakDan's Avatar
00DakDan
Section Moderator
The fuel injectors are 12 volts at the connector. The +12 volt side is constant from the ASD relay. The ground side is switched by the PCM.
Should read 12v to a good ground.
Thread moved to the "tech" forum.
Old Apr 24, 2020 | 12:17 AM
master tech's Avatar
master tech
Site Moderator & Tech
Try replacing the injector and see if you misfire goes away.
