1998 Dakota 5.2 4wd
Old Apr 27, 2020 | 11:55 AM
Floyd Brice Dubois's Avatar
Floyd Brice Dubois
Default 1998 Dakota 5.2 4wd
I have 50 pounds of fuel pressure at idle and 0 @3000 rpms
Old Apr 27, 2020 | 12:04 PM
Does pressure fall off as you increase RPM? I would assume the engine stops running when pressure drops?
Old Apr 27, 2020 | 02:03 PM
Floyd Brice Dubois
Yes at 3000 rpms shut down completely
Old Apr 27, 2020 | 02:09 PM
Floyd Brice Dubois
HeyYou I have 0 pressure @ 3k
Old Apr 28, 2020 | 06:54 AM
Then the pump is failing, or the circuit is failing. Need to find out which. If you hear the pump running, but still have zero pressure, pump is bad.... Otherwise, need to verify you are getting power back there.
Old Apr 28, 2020 | 08:09 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would agree with the pump, But do you have a inline filter?
Old May 4, 2020 | 12:55 PM
Floyd Brice Dubois
Master Tech it was the map sensor
