Dakota 5.2
Old Jul 2, 2020 | 03:42 PM
Floyd Dubois's Avatar
Floyd Dubois
50 psi idling &runing
Old Jul 2, 2020 | 09:24 PM
magnethead's Avatar
magnethead
What's the MAP sensor and TPS reading do as you crack the throttle open?
If it only stumbles/dies on acceleration, tells me it's getting a bad A/F ratio. Does it smell like fuel when it happens?
Old Jul 2, 2020 | 09:53 PM
Floyd Dubois
dies at 3k and smells like it’s running rich
Old Jul 2, 2020 | 11:17 PM
magnethead's Avatar
magnethead
Only while driving, or also while in park/neutral?
That tells me the TPS voltage or MAP reading are off, and it's going rich (premature open loop). Slim chance you could have an injector hanging open at long pulse lengths.
Old Jul 2, 2020 | 11:59 PM
Floyd Dubois
New injectors smells rich all the time
Old Jul 3, 2020 | 12:03 AM
magnethead's Avatar
magnethead
Stock size injectors? Are you sure you didn't go one size too big? I think stock is 23 pound per hour. Would have to see your LTFT and STFT numbers on a logger/analyzer, but it shouldn't smell rich at all times, the oxygen sensors should be dialing back the fuel injector pulse unless it exceeds the 10% tolerance.
Old Jul 3, 2020 | 08:52 PM
Floyd Dubois
i replaced TPS, map sensor , and IAC Valve drove about 1.5 miles stopped running & won’t start back
Old Jul 4, 2020 | 09:50 AM
Got spark? Fuel pressure? Injector pulse?
Old Jul 4, 2020 | 10:54 AM
Floyd Dubois
Default HeyYou
spark into coil not out. Eplaced coil, crank sensor, pickup coil, 50lbs fuel pressure idling and running. New TPS, map sensor, IAC valve
Old Jul 4, 2020 | 11:09 AM
No spark from the coil??? Is that with the new one as well?
