Does the V8 trans bolt into a V6 truck? 2WD
Old Sep 2, 2020 | 10:13 AM
aaron7's Avatar
aaron7
Default Does the V8 trans bolt into a V6 truck? 2WD
98 2WD
Looks like I might need to replace my 42RE soon.
Planning on a V8 swap (someday) so curious; can I use the V8 trans now?
Will it bolt right in? Will the ECU care?
Old Sep 2, 2020 | 06:18 PM
I don't think the ECM will care, so long as the electronics match up. The 46RE is longer though, so, may need a different driveshaft as well.
Old Sep 2, 2020 | 10:25 PM
magnethead's Avatar
magnethead
Grab a 97-2000 46RE (skip the 44; 2001+ wont work at all) and matching driveshaft, throw it in. Computer doesn't know the difference, would be better to use the V6 torque converter, but i dont know if the input and stator are the same on the 42/46. Using the V8 converter might lug the V6 a little.
Old Sep 3, 2020 | 09:53 AM
I think the electronics in the 2000 trans won't match up to what the PCM expects. 96-99 should work fine though.
Old Sep 14, 2020 | 06:35 AM
aaron7's Avatar
aaron7
OK so 96-99 2WD 46RE and driveshaft, with the V6 converter and it should all bolt in.
Does it have to be from a Dak? What about a Ram or Durango?
Old Sep 14, 2020 | 08:12 AM
Don't think it matters what it comes out of, so long as it is for 2wd.
Old Sep 14, 2020 | 09:03 PM
magnethead's Avatar
magnethead
yea, 46RE 2WD is the same in Ram, Dakota, and RamVan.
