Pulling the engine
Old Oct 11, 2020 | 11:03 PM
magnethead's Avatar
magnethead
If your hoist uses 1/2" holes like most, use the M11 head bolts. It's fine. We lift the blower engine with the 3/8" exhaust studs. You're lifting at an angle anyways, so the size difference doesn't matter as much.
Old Oct 12, 2020 | 10:11 AM
Dodgevity's Avatar
Dodgevity
Old Oct 12, 2020 | 09:44 PM
angrysmileyface's Avatar
angrysmileyface
Hell yeah. Definitely like the shorter bolts locations
Old Oct 17, 2020 | 10:25 PM
angrysmileyface
So when I pull the mounts, so I want to just remove the single horizontal bolts on either sideor the 2 vertical ones holding the bracket to the mount?
Old Oct 18, 2020 | 12:42 PM
magnethead's Avatar
magnethead
pull the two 6" bolts going to the frame saddles. The mounts themselves should be able to stay on the block.
