Test on plenum
Old Oct 13, 2020 | 02:45 PM
hidden1's Avatar
hidden1
Default Test on plenum
What is that suction test you can do with the intake hoses to test for blow out or suction to determine a leak in plenum.?
I looked down the intake an didnt see any oil pooling but wanted to look at other tests.
its a 01 3.9 Automatic .
Where else should I be looking to see where the oil is going ?
i have no leaks that are visable but it is using oil more.
Thanks
Old Oct 13, 2020 | 02:49 PM
Disable and plug the PCV system. Take off the oil fill cap. Start the engine. Should be a breeze coming OUT of the fill hole.
Old Oct 13, 2020 | 09:42 PM
hidden1's Avatar
hidden1
Thanks You mean ,like a duct tape method on both the hose to the pcv an pcv end that hose went in ?
Old Oct 14, 2020 | 09:14 AM
Yep, that'll work.
