Check timing and/or ECM on 4.7
Old Nov 30, 2020 | 09:43 PM
Dakota~N~Camaro's Avatar
Dakota~N~Camaro
Default Check timing and/or ECM on 4.7
2 questions
2002 Dakota 4.7
Is there a way to check timing on a 4.7?
Is there a way to confirm the computer is working 100%
Thanks
Old Dec 1, 2020 | 08:49 AM
Timing is fixed, and controlled solely by the PCM. Checking Valve timing, on the other hand...... is likely possible, but, I am not sure how far you would have to tear the engine down to do so.
What problem are you having?
Old Dec 1, 2020 | 08:20 PM
magnethead's Avatar
magnethead
Fundamentally, you can take a sharpie and approximate every 6-10 degrees on the balancer with a tape measure and math, then use a timing light and check all 8 coils. Should have something along the lines of 75 degrees, 165 degrees, 255 degrees, and 345 degrees when the coils fire, presuming "average" idle timing is something like 15 degrees advanced.
Old Dec 1, 2020 | 08:44 PM
Dakota~N~Camaro
thats what i was looking to do somthing without tearing it down.
Old Dec 1, 2020 | 08:47 PM
Dakota~N~Camaro
Think it may of jumped timing.
I have another post, about 4.7 running extremely rough that has all the issues.
Old Dec 1, 2020 | 11:52 PM
98DAKAZ's Avatar
98DAKAZ
Any auto service shop that has a good teck can tell if the timing has jumped ask before you take it in if they can do it for you.
You should watch this guy he's very good at testing for problems.
New Level Auto
https://www.youtube.com/c/NewLevelAuto/videos
Old Dec 2, 2020 | 11:32 PM
magnethead's Avatar
magnethead
If the cam jumped a tooth, it may or may not show up on a timing light.
