Want to put a carbureted 318 in a second gen
Old Jan 12, 2021 | 10:47 AM
Mike Cox's Avatar
Mike Cox
Default Want to put a carbureted 318 in a second gen
What would be recommended to drop a 318 carbureted in a 2000 second gen Dakota that has a 3.9 in it
Old Jan 12, 2021 | 01:31 PM
Issue is going to be gauges, and likely a few other peripheral items. The dash gets all of it's cues from the communications bus, including the gas gauge.... so that's gonna be one problem..... and a tough nut to crack.
Could put the fuel inject 8 cylinder in there, add the additional wiring required (two injectors), and then flash the PCM for the V-8, after all, they were options on your truck.
Old Jan 15, 2021 | 06:10 AM
wheily's Avatar
wheily
i have looked in to doing this my self but from what iv looked in to by the time ur done with all the little things gauges, wiring,tranz control (if needed)...its way cheaper to wire in two more injectors...but it is do abole
Old Jan 17, 2021 | 07:21 PM
volaredon's Avatar
volaredon
As long as his does not have the gray round headed ignition key, (still has the black triangle headed key) he should be able to go to the junkyard and get a computer from a V8 equipped Dakota and plug n play. starting in 01 that was out teh window. (ask me how I know) no flash needed. I didn't know they could flash a V6 computer to make a V8 run.
