98 Dak 5.2 won't idle on startup
5.2 Dak with 195xxx miles, automatic. When I go to start, most of the time won't idle without giving it gas. After a few seconds it'll idle fine. It runs fine once running, doesn't buck or run rough.
I checked the aic (iac?) cleaned the pintle. I might replace it, since they aren't that expensive.
My fuel gauge sometimes goes to empty then back to correct reading. So I'm thinking there might be an issue with the fuel pump/sending unit.
Just want to see if anybody has some insights where to look to tackle this.
