Injector wire size?
Old Feb 15, 2021 | 12:43 PM
StreetWalkerDakota's Avatar
StreetWalkerDakota
Default Injector wire size?
I am doing the 3.9 to 5.9 swap with a 2001 v6 and using a rusted out 2000 Dakota RT. Im adding the 2 injector wires plus the negatives, instead of swapping harnesses.
I have my 2001 5.9 RT pcm and i have the pins for the pcm plug for the 2 injector missing. I have those pin numbers. I just dont know exactly where to get the correct wire... Ive read its a 14 gauge wire but im not sure.
If anyone knows what size it is and even if anyone knows where i could get this correct wire.
Any help would be greatly appreciated!
Old Feb 15, 2021 | 03:19 PM
Can you just swipe 'em from the datota harness?
Old Feb 15, 2021 | 09:31 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'm showing 18 gauge on the driver (negative) side and 16 gauge on positive side.
Primary wire from your auto parts store.
Old Feb 16, 2021 | 09:30 PM
magnethead's Avatar
magnethead
I just grabbed a donor harness and pulled the 2 wires out of it, about a foot worth of both then spliced my own wire onto them (think I used gray on one and purple on the other, both 18 gauge). You'll need the proprietary ends anyways.
