97 dodge dakota sport 2wd metal in oil pan
Old May 4, 2021 | 03:20 AM
Twright92's Avatar
Twright92
Exclamation 97 dodge dakota sport 2wd metal in oil pan
Recently bought ran fine for days up until I decided to change oil. The oil that was drained was over used and not much of it. It was night time when I finished so I only started it and ran it till it got to operating temperature. The next morning I started it up and started to reverse out the drive way as I did she died. Started right back up after the first mile as I am taking the in ramp. A hard knocking noise started ask of lose of power greatly. Long story short I drive it no more then 5 miles with it driving like crap. Did not over heat. The new oil was completely black. Oil was present at intake manifold as well. I was finally able to pull oil pan with great care as I am a student of YouTube. I will attach photos of oil pan ect..
Also I did a motor medic flush.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old May 4, 2021 | 06:29 AM
Moparite's Avatar
Moparite
Looks like bearing material, You kept driving after it started knocking so you may have done more damage. Take off the caps and see what it looks like.
Old May 4, 2021 | 09:59 AM
Twright92's Avatar
Twright92
Already sounds like a good starting point. Thanks for the info I appreciate it and will be posting shortly with further details and would appreciate more advise.
Old May 4, 2021 | 10:12 AM
Twright92's Avatar
Twright92
Also the previous owner changed out the rods. And come to think of it I don't know if he drove it after he changed the rods and I'm not able to get a hold of him not sure if that information would be useful if you might have installed one or two wrong possibly but also the truck ran fine for a few days back and forth to work 30 mi total a day for three days oil was low after I changed oil when problems occurred
Old May 4, 2021 | 10:47 AM
Gonna have to tear it down, and see what's what. Chances are good you will have some rods that you can't re-use, and quite likely the crank will need to be ground, at the very least. Might be cheaper just to find a good used engine, and swap it out. Either that, or pick up a reman long block..... Just depends on how much ya wanna spend.
Looking at the carnage in your oil pan, I would be much more tempted to go the replacement route, rather than the rebuild.
Old May 4, 2021 | 01:14 PM
Twright92's Avatar
Twright92
Default Bearing from front of motor
First set out. How bad is it?
File Type: jpg
File Type: jpg
File Type: jpg
Old May 4, 2021 | 01:48 PM
Those are wasted. How do the journals look?
Old May 4, 2021 | 03:21 PM
Dodgevity's Avatar
Dodgevity
I'd go the replacement route. Consider everything that's supposed to be lubricated by oil, worn out.
Old May 4, 2021 | 03:48 PM
Yup yup. Cam bearings, cam, lifters, rockers, etc. Too much damage to make that one practical for a rebuild.
Old May 4, 2021 | 04:04 PM
Twright92's Avatar
Twright92
Well I appreciate the honesty I will be taking it apart anyhow just because I do have the free time on my hands and we'll need to look at necessary funds for a replacement. Anyone have a ballpark price on an engine new or used. I know y'all probably get irritated with me but maybe about Park price for what you would think would need to be replaced considering my situation. I trust myself more doing it than trusting myself more
I'm going out and finding an engine that is operable we do have a Pull-A-Part and the neighbor's City. But with that said I will keep updated with pics and text as I continue to tear down the engine from the bottom up I guess LOL
