3.9l still stalling please help!!!
Old May 9, 2021 | 03:11 PM
Bobby Drak3's Avatar
Bobby Drak3
Default 3.9l still stalling please help!!!
So i found that my truck is now only stalling while going into gear like if drive for awhile and put it in park at a stop sign it will idle down to 0 i crank it up and it starts up. While driving or idling at 500rpms its hesitant to go
while taking off it gets to 30 - 35mph Then i have to easy off the gas and repeat to get 50mph
Old May 10, 2021 | 09:17 AM
What all have you done to it trying to fix this?
Old May 10, 2021 | 09:35 AM
Bobby Drak3
Engine swap
Crankshaft position sensor
ECU
Radiator
heater core
Battery
swapped throttle position sensor on last engine didn't solve problem
also walk outside to go to work this morning No crank no start. All lights and gauges work as normal no starter no fuel pump no attempt to turn over.
only noticable gauge not fluctuating is oil gauge it only moves when engine starts.
Old May 10, 2021 | 10:16 AM
What brand crank sensor?
When you turn the key to start, do you hear anything click?
Old May 10, 2021 | 11:17 AM
Bobby Drak3
​​​​​​Dead silence b4 it's was coming from glove box but now nothing
Old May 10, 2021 | 11:37 AM
Dodgevity's Avatar
Dodgevity
Pull the neg battery cable for a while to reset things. If the starter still does nothing, try replacing the starter relay. You can swap in other relays as a test.
Old May 10, 2021 | 05:20 PM
Bobby Drak3
If it was in fact the relay my truck wouldnt start at all right. I say that because one day I'll leave it come back and it turns over no problem
Old May 11, 2021 | 02:37 AM
Catin Dillman's Avatar
Catin Dillman
I’m having almost the same exact issue except mine is only stalling in reverse, I was having to push down on the gas pedal and shift with out the brake, which made me cringe every fricken time but at the time I couldn’t figure anything else out. I finally was able to figure out if I shifted the gear shifter past reverse quickly and to drive and then back to reverse it doesn’t stall. But I’m still having issues with it not starting randomly. The first time we changed the plugs and I had one bad one, thought I solved the problem and it did it again Saturday and then tonight. The last two times giving it gas and letting it run while giving it gas it stayed running. But if I let off the gas too soon it died again.
Old May 19, 2021 | 09:53 PM
Joe Rather's Avatar
Joe Rather
I am just curious if you guys have checked your grounds and/or swapped out batteries. I've got an 02 3.9 Dakota as well as a 96 ram 1500, both trucks started having these issues and it ended up being fixed by putting a new battery on. (after tons of $$$ and even more headaches) good luck!
Old May 19, 2021 | 10:03 PM
Bobby Drak3
Yes ground checked and fixed
battery replaced
Pmc replacedEngine replaced
Radiator and heater core replaced
Next fuel pump
And cat
