2002 Dakota 4x4 Sport 3.9 miss.
Old May 30, 2021 | 01:31 PM
kwcabin3's Avatar
kwcabin3
Default 2002 Dakota 4x4 Sport 3.9 miss.
My 2002 Dakota 4x4 Sport with 3.9 has a miss and will stall unless you restart and miss disappears. I have changed plugs, fuel injectors, pvc, shift sensor, rotor cap, computer everthing I can think of. Any suggestions. Thanks
Old May 30, 2021 | 04:25 PM
Getting any codes? Random misfire? Or specific cylinders?
Welcome to DF! Moving this to second gen Dak section for ya.
Old May 30, 2021 | 04:51 PM
kwcabin3's Avatar
kwcabin3
No codes
Had codes over a year ago.. misfire on cylinder 3. Replaced all injectors code cleared. Replaced MAIR, Coil, wiring and sprayed foam. Two bottle of Lucus through gas lines.. Furl pressure good and all voltage checked out.. Help
Old May 30, 2021 | 07:32 PM
Compression, or leakdown test.
