Broken brake light
Old Aug 28, 2021 | 03:40 PM
LEDshot's Avatar
LEDshot
Default Broken brake light
What would cause one brake light to not work when the lights are on?
Old Aug 28, 2021 | 11:41 PM
ol' grouch's Avatar
ol' grouch
Brake light or tail light? The brake lights only come on with the brakes applied or the emergency flashers going. The tail lights come on with the head or park lights. If one isn't woking then, swap it with the other side to make sure it's not burned out. Beyond that, it could be a bent prong on the plug to the assembly, a bad wire or a bad ground. Usually, a bad ground will cause it to be dim, unless you have LED bulbs and thise are either on or off. They won't work at all with a weak ground
Last edited by ol' grouch; Aug 28, 2021 at 11:42 PM. Reason: i kant spel wurth a durn
Old Aug 30, 2021 | 11:35 AM
00DakDan's Avatar
00DakDan
Section Moderator
What year? Looks like an '01+ in the pic.
They all share the ground. But, each brake light get their power from the combination flasher. It controls the turn signals/brake lights.
Old Aug 30, 2021 | 11:33 PM
LEDshot's Avatar
LEDshot
Clearly stated, brake light.
Old Aug 30, 2021 | 11:34 PM
LEDshot's Avatar
LEDshot
04 3.7 5spd manual
Old Aug 30, 2021 | 11:49 PM
LEDshot's Avatar
LEDshot
Brake lights function properly until headlights switch is engaged. With parking lights and/or headlights switched on the left brake light/tail light shuts off.
No, it's not the bulb and yes, I've switched out the socket.
Old Aug 31, 2021 | 10:10 AM
00DakDan's Avatar
00DakDan
Section Moderator
The headlamp switch and combination flasher share a ground. It's a "sense" circuit, low current to trigger the CTM outputs, on both.
Should be on the side of the instrument panel. Follow the harness down from the CTM, it'll branch off.
Old Aug 31, 2021 | 08:52 PM
LEDshot's Avatar
LEDshot
CTM? Central timer module?
Old Sep 1, 2021 | 08:44 AM
00DakDan's Avatar
00DakDan
Section Moderator
Yes, Central Timer Module.
