Carrier bearings
Old Sep 9, 2021 | 08:45 PM
hidden1's Avatar
hidden1
Default Carrier bearings
I got the differential out on my 01 ,2wd automatic. What tool works best on carrier bearings ? It it tight there an not a big lip to hook to.
Also should I look at the pinion bearing an how do i tell if the bearing in it is bad without taking it apart..
got outside bearrings off but inside is in there ..
Thanks
Old Sep 10, 2021 | 08:56 AM
One of the clamshell style bearing pullers, and a press.......
Old Sep 10, 2021 | 10:57 AM
hidden1's Avatar
hidden1
Took it in to shop..had em off an new on for $30 in 15 min👍
What is the ft lbs on the 4 big bolts that hold the 2 bearings in ? An anything i should try to see at front pinion before reinstall of diff.. ?
Old Sep 10, 2021 | 11:04 AM
You want to pull the pinion, and look at those bearings as well. The outer bearing is the one that usually goes bad first. New seal would be a good idea too. Keep in mind, I do believe there is a crush sleeve in there, and you will have to replace that as well.
If you have an inch-pound torque wrench, take a reading on just how much it takes to turn the pinion, and when you reassemble, try to get as close to that number as you can.
Old Sep 10, 2021 | 01:57 PM
hidden1's Avatar
hidden1
After talking w several people Im not gonna take that apart..very technical on that. Yea Im chancing it at pinion but know all my 4 bearings are new.
if i disconnecr drive shaft an spin it freely will that tell me if thats the issue?
Note i didnt hear hum til after 20mph an cant turn it that fast by hand.
What Ft lb for carrier cover bolts?
IS IT 100 FT LBS?
Old Sep 11, 2021 | 08:20 AM
Glen440's Avatar
Glen440
These rear ends are known more for bad pinion bearings than carrier bearings. This is the time to do them with the carrier out. I have not been inside one of these but a little research will get you the specs. A cheap needle type inch lbs torque wrench will work for the pinion pre load.
Old Sep 11, 2021 | 11:06 AM
hidden1's Avatar
hidden1
What does this screw adjust exactly.Its on a clip to the notched wheel by bearing ?
Old Sep 11, 2021 | 11:14 AM
That is just a lock for the adjusting nut. Adjust it where you want it, torque everything down, then put the clip/bolt in, to hopefully keep it from turning.
Old Sep 11, 2021 | 12:09 PM
hidden1's Avatar
hidden1
Thats what I thought .Not sure why its so adjustable . I put it back as originally in.
How tight should i fiT that slotted wheel in into cover. Against bearing?
Enough to let bearing an diff have a bit of movement 1 slot edge viewable on outside.
Old Sep 11, 2021 | 12:37 PM
On those, I am not sure. Should be a procedure for setting backlash in the service manual. If you don't have one, we have several available in the 2nd Gen Ram FAQ/DIY section. They are for full sized trucks, but, I think its the same axle.
