New to me QC 4wd
#21
#22
#23
#24
They are going to get swapped anyway, "working or not". What happens to them is as they age the field strength of the magnet deteriorates and the actual rise time of the sensor starts shifting causing timing to slip. Swapping in new sensors brings them back in alignment. The main reason is 2 fold, 1 keep it crisp and 2 prep for diving into tuning it with HP tuners.
#25
#26
both front bearings swapped, found a sticky ds caliper and a stripped slide bolt mount hole in the knuckle. this causes the retaining spring to dig into the rotor. nice. if i i c comfortably helicoil the hole, will buy brakes for up front. if not, will switch to '03 dual pistion setup.
picked up a set of ngk plugs, will do those sometime this week, expecting to find a stripped plug hole..
also going to revisit the 190* stat swap.
#27
#28
Try https://www.car-part.com/ plenty of them around, maybe you can find a yard that will ship internationally...
#29
I know Steve, but 99% don't ship international, have tried for maybe 20 times, by chat and mail, different yards.
Thing is they all back out if you throw part numbers and ask for pictures before sending.
I've read so many times they send wrong part numbers, same thing with junkyards over here, and i can't return them because of time spend and cost, ( USA to Netherlands and back again ).
I have a shipper in Kent WA 98031, this is a Dutch family who lives over there and set up a shipping line to the Netherlands.
Spoke to them, and if delivered to them, they send the parts over, no problem, he will even check if they are the right parts or part numbers but he doesn't come in between if the parts delivered at his house are the wrong ones.
So i gave up on buying used from junkyards in the USA.
#30
