No buss -code
Old Nov 11, 2021 | 08:33 PM
divco13's Avatar
divco13
Default No buss -code
Replaced the heads on a 2002 / 4.7.... I have cranking but,... I get a Fault of NO BUS.. after cranking for bit., no start......I have a full set of manuals for a 2002 Dakota. Do not see any description of the no bus meaning ? or diagnostics fix.
Have fuel pressure, Starter cranks, no start.. I know it is wiring fault. Not sure where to start. I do have the cam timing correct.
Old Nov 11, 2021 | 10:29 PM
divco13's Avatar
divco13
Found, No Bus video on U-Tube.............................
I did find two ground straps broken, had to fix them.
Old Nov 12, 2021 | 07:39 AM
Originally Posted by divco13
Found, No Bus video on U-Tube.............................https://www.youtube.com/watch?v=c3qp7oXfh2M I did find two ground straps broken, had to fix them.
Did fixing the grounds solve the no bus?
Old Nov 19, 2021 | 10:55 AM
divco13's Avatar
divco13
I also have broken ground wires on the RF fender well. It goes from engine block to a weld stud on RF inner fender. Also on the same ground wire, it has a third connection where does it go ??......
