Need..2002 dodge dakota 4.7 ignition capacitor-ignition
Old Nov 17, 2021 | 02:16 PM
divco13's Avatar
divco13
Default Need..2002 dodge dakota 4.7 ignition capacitor-ignition
What happens when a 2002 dodge Dakota 4.7 ignition capacitor-ignition fails ?? Crank's have fuel no start. I believe this is a ground filter for ignition. Coils !..
No listing at Parts store's. Needs not be a Mopar part.
Right front inner fender, mounted on weld stud. No continuity thru Capacitor.
Crank no start have fuel pressure
Old Nov 17, 2021 | 02:33 PM
steve05ram360's Avatar
steve05ram360
You're not going to get continuity thru a cap, if you do its bad...
https://en.wikipedia.org/wiki/Capacitor
Old Nov 17, 2021 | 03:06 PM
divco13's Avatar
divco13
My understanding this is the 5 volt ground for the coil circuit. Finding a replacement is Problematic.
Old Nov 17, 2021 | 05:12 PM
steve05ram360
Download the manual and verify what it is. A ground will not have a serial cap on it, a coil can though.
Old Nov 17, 2021 | 06:26 PM
divco13's Avatar
divco13
I have the complete set of Manuals. Pic below..... What is the meaning, of will not have a serial cap on
Old Nov 17, 2021 | 07:27 PM
steve05ram360
now it is making more sense the cap is most likely holding a charge for the relay to stay engaged. find the circuit in the schematics/wiring diagram and see how it is connected to the relay.
i would bet it is a part used over many dodge models. pull that part off and take steel wool or a sanding wheel to clean up the tab and reinstall. you can also measure its value after the cleaning with a volt meter that has capacitor functions.
Old Nov 18, 2021 | 07:20 PM
divco13's Avatar
divco13
It has no continuity thru the module. I finally got a dealer to find the part. I'll have it Saturday, I hope. I'll post the results. Cowboy thank you for your input, I appreciate your time and effort.
I hate be uninformed about computer controlled motors.,. I'm old school. 48 divco BBC 502
Old Nov 19, 2021 | 02:51 PM
V8Cowboy's Avatar
V8Cowboy
[QUOTE=divco13; [s]Cowboy Steve05ram360 thank you for your input, I appreciate your time and effort./QUOTE]Credits are for others on this one, i just learned something just like you
