Guages not working
Old Nov 25, 2021 | 04:32 PM
Jamscor's Avatar
Jamscor
Default Guages not working
I replaced the fuel pump now my guages aren't working ,any help
Old Nov 25, 2021 | 09:15 PM
Does it start and run?
Need to tell us what you are working on as well.
Old Dec 2, 2021 | 09:17 PM
Jamscor's Avatar
Jamscor
Yes it starts and runs,2003 dakota 5.9L the overhead display fluctuates but the needle won't move
Old Dec 3, 2021 | 10:29 AM
Do a cluster test. Press and hold the trip reset button, turn the ignition on. Cluster will start the test in a couple seconds. (you can let go of the button.) All gauges should sweep thru their full range, and all lites should test. Does everything work the way it is supposed to?
Old Dec 3, 2021 | 08:32 PM
supadoom's Avatar
supadoom
When you did the fuel pump did you face the pump with the arrow inside the double lines? If you don't do that the float can get stuck on the side of the tank. (Assuming your just talking about the fuel level gauge.)
Old Dec 4, 2021 | 08:55 AM
Jamscor's Avatar
Jamscor
I guess that's something I should double check,thank you for the info.
