Charging issue is back
Old Dec 2, 2021 | 12:32 AM
  #21
hidden1's Avatar
hidden1
Yep they hook up the 2 wire plug on testing !
I put one off a 8 cyl , but same # as 3.9 6cyl in it.tested good an 14.1 . But we will see if does the same thing..
Old Dec 2, 2021 | 10:46 AM
  #22
This is just a wag, but, I wonder if engine temp doesn't play a role? Maybe if the PCM thinks the engine is getting hot, it will turn off the alternator to lessen the load??? I know some of the newer cars will do this trick, but, no idea how far back that goes.
Old Dec 2, 2021 | 11:57 PM
  #23
magnethead's Avatar
magnethead
My 2001 most definitely does not do this.
Battery temp sensor could be a culprit yes; but since a physical whack fixes the issue, i'm still thinking it's field/core related.
Old Dec 3, 2021 | 10:27 AM
  #24
Yeah, I'm gonna agree with ya on that one.
Old Dec 3, 2021 | 10:14 PM
  #25
hidden1's Avatar
hidden1
That replacement seems to be holding up fine..It must have been the diode or a short if it gets hot ..very odd to test good even on diode test [ but that's NOT when it's hot] .
Hadn't changed plug to it .
Glad it's not the pcm.
Old Dec 7, 2021 | 01:45 AM
  #26
Vimes's Avatar
Vimes
If the problem returns, check around to see if you have a local rebuild shop. You'll get a better rebuild from them than from the parts store. I'll only buy one from a parts store in an emergency now, if I have a few days it's off to the local shop for a rebuild.
