2000 Dakota 5.9
2000 Dakota 5.9
So I've heard plenty about the 5.9's having issues with jumping teeth. This made me think about how I could check the timing chain out without pulling the engine. Could you just pull a spark plug on each bank and turn the engine till TDC and check the location of the rotor? IE: Bring cylinder 1 to TDC and verify that the rotor is on cylinder ones point? If that wouldn't work is there another method? Pulling the valve covers?
Pull the distributor cap, and position a mirror so you can see if from the front of the truck. Turn the crank so #1 is at TDC, ONLY turn the crank clockwise to position the cylinder. Once it's there, turn the crank backwards, until you see the rotor start to move. Supposedly, about 10* of rotation is OK, more than that, and it's time for a new chain/gears.
If you are close to 100K miles on it, (or over that....) it's likely time for chain and gears in any event.
So I did that and its sitting pretty much dead center. I'm thinking the previous owner must have done a timing job on it when they did the cap & rotor. Also I ended up cracking a spark plug. The plug had less than 1000 miles on it. Is there something that causes that or would it just be a bad plug. NGK plugs for info.
We've had a few be dead out of the box. Most we catch on warm-up, but a couple have been fine at low RPM but failed at high RPM. Makes for a really unhappy engine.
