Most common diff
yes and no.
The 9.25 is in almost all durangos to my knowledge. Some got the 8.25 but i don't know what the criteria were.
The 9.25 is under almost all Quad Cab dakotas and all Dakota RT's. It's also under the Ram 1500's.
The 8.25 is under all non-RT regular and extended cab Dakotas, as well as some Jeep XJ Cherokee's (some got a Dana 35 instead).
The main difference is if they are spring-over or -under axle, and how far apart the spring perches are. Durango IIRC are ~2" wider than Dakota, ~1" per side? But same flange width.
I don't know if the Cherokee is closer to the Dakota or Durango on perch width. I think Flanges are pretty similar, but they are also 5-lug. Ram is obviously wider in both perch and flange.
Also note that regarding 8.25; 00 and older are 27 spline axles, 01 and newer are 29 spline axles. Same diameter, just different spline count.
yes and no.
