Oil pan gasket & oil pump replacement 1999 dodge Dakota sport 5.2
Old Dec 20, 2021 | 10:49 PM
Lil99D's Avatar
Lil99D
Default Oil pan gasket & oil pump replacement 1999 dodge Dakota sport 5.2
After i finally removed the oil pan,I noticed this discoloration. Any thoughts
on what it is
Its like the metal is stained?
Old Dec 21, 2021 | 09:54 AM
Its from hot oil. Perfectly normal.
Old Dec 21, 2021 | 10:19 PM
Lil99D's Avatar
Lil99D
Default Rear main oul seal?
Thanks, also do you think I should replace the rear main seal since I m putting a new oil pump in. I really don't ever wanna do again!
Old Dec 21, 2021 | 11:19 PM
magnethead's Avatar
magnethead
I would, since you are there.
Old Dec 22, 2021 | 10:16 AM
Yeah, rear main seal is two more bolts.
Old Dec 24, 2021 | 08:22 PM
hidden1's Avatar
hidden1
Yep definately replace the seals .Its pretty easy too.I changed mine when i put a new pump in.
