WTB: NV3500 manual transmission for V8 Dakota.
Old Dec 31, 2021 | 03:18 PM
stormbride1's Avatar
stormbride1
Default WTB: NV3500 manual transmission for V8 Dakota.
Looking for a good working NV3500 for my manual swap into my 99 dakota RT...anyone have one laying around
Old Dec 31, 2021 | 04:17 PM
stormbride1
ok doing some research here at work. One of my coworkers just stated that the NV3500 used in the late 90's early 00's Chevrolet 5.0 and 5.7 trucks is the same transmission with all the same bell housing, bolt holes, everything with the only difference being the gear ratios? Is this true? Any Mopar Mavens here that can confirm? There are a ton of Chevrolet manual trucks at the pick and pulls...I even looked them up on the computer here at AutoZone and they look identical....
Old Dec 31, 2021 | 11:47 PM
savethemanuals's Avatar
savethemanuals
According to Wikipedia where it says “similar transmissions”, no. I am not 100% sure, but everything I have read says that they have the same internals, but the bell housing bolts are different.
https://en.m.wikipedia.org/wiki/New_...0_transmission
Old Jan 1, 2022 | 10:06 AM
Yeah, bellhousing bolt pattern is going to be different between manufacturers..... A gm-sourced trans, won't bolt to a Dodge engine.
Old Jan 1, 2022 | 10:18 AM
stormbride1
ok thanks for the information. Ill keep searching for that elusive transmission.
Old Jan 1, 2022 | 01:33 PM
Search for the NV4500 as well, it will live longer behind the 5.9. (3/4 and 1 ton trucks with manuals got the NV4500)
Old Jan 1, 2022 | 02:06 PM
stormbride1
ive heard the NV4500 is the better transmission no doubt but also have seen where it is 2" taller and wont fit in the stock trans tunnel of a dakota. I dont plan on bashing on the R/T toooo much. Currently working on the kegger mod at work during lunch breaks and searching for a 53MM throttle body. I already picked up the aluminum plenum pan to replace the this stock steel one.
Old Jan 1, 2022 | 02:08 PM
Fastman, and I think Hughes offer larger throttle bodies.
Yeah, didn't consider the lack of space in a Dak for the bigger trans.
Old Jan 1, 2022 | 02:10 PM
stormbride1
I just went to the SCT website to look at tuners and it shows nothing available for the 5.9 Dakota. Is there a different provider for tuners. Thats my biggest concern right now at this stage is getting the ECM issues sorted as I still have a couple years left of emissions testing here in New York.
Old Jan 1, 2022 | 02:13 PM
stormbride1
Id rather get a yard ECM and have it flashed or programmed and keep my original, original if possible. just seems to be a lot of conflicting information at there on the webs. Been doing alot of reading over last few months as ive been acquiring the parts.
