Junkyard PCMs...
This is amazing ...... I was thinking on doing the same.......
Either change the seats/cushion ore go to the junkyard and find some other seats to change over...
For the PCM part, i also think there would be no problems, only the keyless maybe.
Are you afraid the PCM is going to fail at some point ? Because if you've got info on that, it might be something i should look into, because there are non available over here.
So the seats have a slightly higher bolster on the inner side. Not sure if it's because the outer side is compressed with use, or designed that way from jump. Once the passenger cushion assembly is moved to the driver's... that higher bolster will be on the outside.
I've also got this issue with my driver's seat. There is a large plastic washer at the end of the power assembly worm screws that wears out. Once that happens, there is a slight movement or a click felt within the seat (nothing you can hear) every time I stop or move off from standing. Imagine your seat shifting a quarter inch each time... pretty annoying. I had resolved it many years ago and it's slow creeping back as the washers wear... this time I'll use metal washers even if I have to shave it down with a grinder.
I don't think it will fail, but you've got to be prepared for any eventualities when you're driving till the wheels fall off.
The following users liked this post:
V8Cowboy (02-16-2022)
Here is the thread on mine... (1) Genos Seat Foam and Cover Review | Dodge Cummins Diesel Forum (cumminsforum.com)
Maybe there is something of use in there. What we found on the ram was the foam would split in the area where it met the frame on the outer edge. I added a support piece to help shore it up so it held up better with the day to day use. Even with side steps, still slide out of the truck which puts pressure on that area and ultimately tearing it.
Dodgevity (02-16-2022)
