aux water pump?
Old Feb 19, 2022 | 01:03 PM
steve05ram360's Avatar
steve05ram360
Default aux water pump?
dumpster diving @ the jy for the brake upgrade and came across what look like an aux water pump sitting near the passenger side firewall, did dodge ever put one in? looks like an after thought install...
Old Feb 19, 2022 | 02:58 PM
Dodgevity's Avatar
Dodgevity
Never heard of one. Pics?
Old Feb 19, 2022 | 04:49 PM
steve05ram360
yes took a pic and found it is an oem install, found it on another 4.7 durango, pic i took had a repair done to it. heading back to jy to get spindles for brake swap & will snap pic of the unmolested one
Old Feb 19, 2022 | 04:54 PM
steve05ram360
google this "durango 4.7 auxiliary water pump " and should see pics of it...
Dodgevity's Avatar
Dodgevity
Probably for circulating the coolant to the heater lines/core for the rear cabin.
Old Feb 19, 2022 | 05:00 PM
steve05ram360
separate heater core for rear? will investigate...
Old Feb 19, 2022 | 05:38 PM
Dodgevity's Avatar
Dodgevity
Yeah... this is the rear assembly. The red circle was pointing out a leak in the line for this particular unit. That's probably the core right where the line attaches.
Old Feb 19, 2022 | 08:22 PM
magnethead's Avatar
magnethead
Yes, durango rear heat has it's own heater core and a small pump to send hot coolant to it.
Old Feb 20, 2022 | 08:52 AM
steve05ram360
adding general info...
https://www.knowyourparts.com/techni...y-water-pumps/
