I replaced the plugs an noticed this stuff on the side of 2 .Is it just crud from fuel additives ,an what does that possible mean on how its doing.Its tan looking.
Also ,do you recommend Champion,NGK,Autolite?
Thanks
Thanks..
i changed back to the NGK ~~ no more hesitation👍
Ill NEVER use autolite on the dakota EVER again.,an im not fond of champion either ,...besides ,the autolite is longer an caused some weird hesitation as you sit at a light..
An that slight lifter tick[ common in these trucks ] is gone now too after cleaning out the throttle an IAC -deeply ,- along w plugs an rotor/ cap .
