P0171 code fix
Old Apr 15, 2022 | 09:41 PM
Jamscor's Avatar
Jamscor
Default P0171 code
So it may not be my Map sensor?so could be the Mas sensor if that's bad it will show a lean code ,yes?
Old Apr 15, 2022 | 10:46 PM
supadoom's Avatar
supadoom
Pretty sure your truck does not have a MAS. Most older vehicles only have a MAP sensor. A MAS sensor is just a different way to calculate how much air your engine is pulling in. It will usually make it run rich when its dirty.
Old Apr 18, 2022 | 10:28 PM
Jamscor's Avatar
Jamscor
Default P0171 code
Ok I replaced my TPS after testing the voltage output and it was below 5vs,so I replaced it with a new one and the engine reved up to like 1800,was there a step I missed when installing the new TPS?
Old Apr 18, 2022 | 10:38 PM
hidden1's Avatar
hidden1
Did you buy the oem sensors,especially on 02 sensor ?
-these trucks hate off brand sensors.
Check the connector to it .
Replace pcv too an check that the fuel pressure is normal. Both can factor lean code
Old Apr 18, 2022 | 10:56 PM
supadoom's Avatar
supadoom
I'm assuming you mean it revs automatically without you doing anything, right? You might have installed it upside down or it could be a junk sensor. I would lean towards a bad sensor. I don't think you can install them wrong on this type. Without the truck running try manually opening the throttle plate all the way. If you installed it wrong it will bottom out the sensor before its opening completely.
Old Apr 19, 2022 | 10:32 AM
Jamscor's Avatar
Jamscor
Default P0171 code
No unfortunately I didn't get the OEM parts they were to hard to find
Old Apr 19, 2022 | 10:43 AM
hidden1's Avatar
hidden1
Then at least get one off a identicle truck.Thats better than a new off brand.
Your non oem sensors can behave totally incorrectly depending on brand . What brands are the sensors you put on?
Old Apr 19, 2022 | 10:54 AM
Jamscor's Avatar
Jamscor
Default P0171 code
O'Reilly, auto trend or something
Old Apr 20, 2022 | 10:13 PM
Jamscor's Avatar
Jamscor
Default P0171 code
Would having my ECU flashed have anything to do with the truck not recognizing the new parts?
Old Apr 20, 2022 | 10:50 PM
hidden1's Avatar
hidden1
Again.I would not leave the off brand sensors in. At least rule them out an put the used mopar on to eliminate that . Reset ecm an retest.
.[tons of reads on off brand sensor problems on the site]
Reflash wont fix it.
Are there any exhaust leaks?
