New Member from Central KY
Old Jun 30, 2022 | 10:02 AM
mopardug's Avatar
mopardug
Default New Member from Central KY
Hi all. I recently joined because I picked up a '04 QuadCab 2WD and she needs some help...and $$ lol
She's got the V-6/auto. When she's running, you don't need to spray for mosquitoes.
We have a '79 Magnum 360 4-bbl/auto that runs...no title.
I'm lazy, and don't have a lot of time. And I've been away from the game since '00.
I want to drop the drivetrain from the Magnum in the Dak. I want to keep the carb, P/S, AC.
I've been told that I needed to do a 5.9 Magnum instead of the LA. I do have a 5.9 shortblock, but it'll probably need rebuilt.
The money tree that we planted in the back of the house has died without bearing any fruit. .
I haven't had a 'Hot Rod' since '99, and the bell curve is getting shorter.
Thanks for letting me join.
Old Jun 30, 2022 | 10:50 AM
Problem is, EVERYTHING in the cab is driven/controlled by the computer. You can't eliminate it, without essentially rebuilding the entire electrical system...... A project that does not align with 'lazy' very well at all.
Old Jun 30, 2022 | 11:23 AM
ol' grouch's Avatar
ol' grouch
A lot of the LA and Magnum engines is shared. Then again, a lot of the our DNA and that of Chimpanzees is shared. It's those little details that make the difference. There is so much different, you're looking a prohibitive cost to swap it in. Find a wrecked truck and swap engines. That would be the easiest to do. Both in labor and cost.
Old Jun 30, 2022 | 01:25 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Should probably put this in the Dakota section.
Old Jun 30, 2022 | 02:44 PM
Correct!
Moving to second gen dak section.
Old Jul 6, 2022 | 03:35 AM
magnethead's Avatar
magnethead
You'll need engine mount adapters from HiPoTek to go from the LA mounting ears to the Magnum 'Saddles'. But as mentioned, you'll have no dash after the swap.
