Noise only when in 4WD
Old Oct 8, 2022 | 11:41 AM
04dakV6's Avatar
04dakV6
Default Noise only when in 4WD
When only in 4WD it sounds like a bad wheel bearing. I'm not going to say a grinding noise but it sounds like a bad wheel bearing.When only in 2WD no problem. Any thoughts?Thanks
Old Oct 8, 2022 | 08:36 PM
supadoom's Avatar
supadoom
Is it making a ticking noise at all? Does it change with vehicle speed? Does it change if its in 4 low vs 4 high? It's probably the Pinion bearing on the front differential.
#9 and #4.
Old Oct 9, 2022 | 12:14 AM
04dakV6's Avatar
04dakV6
I've only driven the truck in 4WD high during the winter days when there is snow on the road. Noticed one day when I put in 4WD high that I noticed the noise, never did it before that day. No ticking noise , it's does changes in vehicle speed, not noticeable at higher speeds just low speed.
Old Oct 9, 2022 | 09:36 AM
Check fluid level in the t-case, and front axle.
Old Oct 10, 2022 | 12:17 AM
04dakV6's Avatar
04dakV6
Yes I am planning on changing the fluid in the T-case and will update when done. By the way can I test the 4WD on pavement or asphalt after I change the T-case fluid?
Old Oct 10, 2022 | 07:39 AM
NO! Do NOT engage 4x4 on a high traction surface, that tends to break things.
Old Feb 15, 2023 | 09:26 PM
04dakV6's Avatar
04dakV6
Default Noise in 4WD update
Problem was the cv joint on the front drive shaft.Good to go again. Thanks everyone for all your input
