Radiator replacement
Old Jan 2, 2023 | 09:56 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by magnethead
wanted to cross check you that it's for the 2.5 as specified initially by OP
Crap, forgot what he was working with. Good catch. He should look for the 2.5 version.
Thx
Old Jan 2, 2023 | 11:12 PM
rickself's Avatar
rickself
Nothing special on the water pumps. Just no "cheap crap" for the sake of the shaft seal/bearing. I have a FlowKooler on mine, but ran a store brand "premium" on the V6 before that without issue.
Thanks magnethead. One would hope that a middle of the line price would be a good pump. Not like this grandpa is goin racing!
Thanks
Old Jan 3, 2023 | 01:45 PM
Dodgevity's Avatar
Dodgevity
Got the right part this time... Only $36.
Amazon Amazon
Metal impeller and GMB is a bearings maker. That's usually the part that fails.
Old Jan 3, 2023 | 02:33 PM
rickself's Avatar
rickself
Got the right part this time... Only $36. https://www.amazon.com/GMB-110-1090-...ot_top?ie=UTF8
Thanks, Dodgevity, order placed. RockAuto has it for almost the same price so went through them.
So now I have the radiator, both upper and lower hoses and the water pump. Anything I'm missing that should be done at the same time? I'll make sure the mechanic does a back-flush also.
Old Jan 3, 2023 | 06:21 PM
Thermostat?
Old Jan 3, 2023 | 06:32 PM
rickself's Avatar
rickself
Thermostat?
Good point.
I actually have a new one but apparently I mentally had a cost limit for my list! I even found a new reservoir cap that cost about the same as the thermostat.
