Swapping Durango parts to Dakota
Old Nov 2, 2022 | 05:56 PM
DakotaBruce21's Avatar
DakotaBruce21
Default Swapping Durango parts to Dakota
Will the spindle and brakes from a 04 Durango 2 wheel drive fit on a 01 Dakota 2 wheel drive? Wanting to swap back axle also for disc brake up grade. Any information would be really appreciated. Thank You
Old Nov 2, 2022 | 07:44 PM
supadoom's Avatar
supadoom
I know the 03 Durango brakes/knuckle do. Its part of the dual piston upgrade that I assume your going for. I don't believe they changed the brakes from 03-04 on the Durango. The rear brake upgrade is custom parts as far as I know and you'll either have to decide on how you want to handle the parking brake.
Old Nov 2, 2022 | 10:15 PM
magnethead's Avatar
magnethead
yes, swap the entire spindle assembly to do it easiest, ball joint to ball joint. That's what I did.
Old Nov 3, 2022 | 03:06 AM
Dodgevity's Avatar
Dodgevity
03-04 was a drastic change, as Durangos went from gen 1 to gen 2. I don't know for sure, but my guess is it won't fit.
Old Nov 3, 2022 | 10:10 PM
supadoom's Avatar
supadoom
Ah I thought the Durango's switched the same year as the Dakota's. In that case it most likely changed...
Old Nov 3, 2022 | 10:31 PM
magnethead's Avatar
magnethead
Nope, only the body changed for those years. The chassis was the same, at least at the wheel ends. Chassis changed to 5-lug in 05.
I went to the junkyard, found an 04 durango, knocked the 4 balljoints and 2 tie rods loose, and came home with a heavy, expensive, full wheel barrow.
Knocked the 4 and tie rods off my 01, bolted on the 04's. Brake lines, ball joints, tie roads are all the same.
Old Nov 4, 2022 | 09:12 AM
Dodgevity's Avatar
Dodgevity
04 Durango is five lug. https://www.carparts.com/details/Dod...E&gclsrc=aw.ds
Just so we are clear, this is an 04 durango.
https://www.allpar.com/d3/model/durango-2004.html
Old Nov 6, 2022 | 07:38 AM
DakotaBruce21
Default Thank you
Thank you all for the information you have been very helpful this is a great place to learn one day I hope to have a bad azz Dakota right now it’s a extended cab V6 one wheel peel lol
Old Nov 8, 2022 | 12:05 AM
magnethead's Avatar
magnethead
Found my original thread post: https://dodgeforum.com/forum/2nd-gen...ml#post3423204
I thought I had a post with part numbers for the front brake swap, but I guess not.
Donor Platform: 2003 Dodge Durango 2WD
Oreilly retail pricing
Front Left Caliper Only: 18-4877, $48.99 + $35 core
Front Left Caliper + Bracket: 18B4877, $54.99 + $42 core
Front Right Caliper Only: 18-4876, $48.99 + $35 core
Front Right Caliper + Bracket: 18B4876, $54.99 + $42 core
Front Left Brake Rotor: 780133RGS, $74.99
Front Right Brake Rotor: 780133RGS, $74.99
Brake Pads, Set: MKD966, $21.99
Left Upper Ball Joint: K7392, $92.99
Left Lower Ball Joint: K7393, $94.99
Right Upper Ball Joint: K7393, $92.99
Right Lower Ball Joint: K7393, $94.99
Price to replace everything: $281.95 for brakes + $185.98 for UBJ + $189.98 for LBJ = $657.91
It looks like O'Reilly's hates MOOG. Rockauto has the ball joints WAYYYY cheaper.
K7393 $36.99 Lower
K7392 $37.79 Upper
$281.95 + $75.58 + $73.98 = $431.51
NAPA Retail Pricing is pretty much the same:
Front Left Caliper + Bracket: CAL SE5428A, $54.99 + $27.78 core
Front Right Caliper + Bracket: CAL SE5427A, $54.99 + $27.78 core
Front Left Brake Rotor: NB 48880133, $79.99
Front Right Brake Rotor: NB 48880133, $79.99
Brake Pads, Set: TS TS7868M, $21.99
