Starting the build process
Old Nov 22, 2018 | 07:38 PM
  #221
magnethead's Avatar
magnethead
Front springs are ordered via 10% off sale and free shipping for Black Friday at Landrum. Now tallying up the bill for what it will take to rebuild these junkyard spindles so I can get them put on.
Hard to believe it's been 2 years and 7 months since I started this project. Not to mention 220 update posts.
Old Nov 30, 2018 | 11:09 PM
  #222
magnethead's Avatar
magnethead
Throttle cable/pedal assembly - done
New Coil Springs - In Hand
Fuel Filler Hose for Fuel Cell - In Hand
New 16" Front Runner Wheels - In Hand and mounted with new 225/65/16 tires
Magnafuel Pump and Filters - Arriving Tuesday
Orme Brother Fittings - Arriving Tuesday
Need to get an internal spring compressor for the coil springs and Rebuild the new front spindles (about $250).
I got new trailer harness connectors, and rebuilt the trailer harness for the truck side. I also made a 7 pin to 2 pin connector for connecting my solar panel charger. This makes it super easy to plug/unplug the charger when I want to drive the truck.
Old Dec 9, 2018 | 06:33 PM
  #223
magnethead's Avatar
magnethead
Fuel pump assembly will nearly be frame rail to frame rail in the back. Have the rest of the fuel system shipping out tomorrow.
Picked up the new-to-us rear wing for the dragster from TRL's old stomping grounds.
Old Dec 10, 2018 | 07:29 PM
  #224
XSubaruJeepDude's Avatar
XSubaruJeepDude
Can you see the Trans Oil Temp gauge pretty easily from the drivers seat?
Old Dec 10, 2018 | 10:23 PM
  #225
magnethead's Avatar
magnethead
Yes, from my preferred driving position, it is a straight shot though the right spoke window of the steering wheel. The shift/gear indicator is right over the factory one, through the top window of the wheel.
My driving position is close and tight, not many people prefer that config. So YMMV.
Old Dec 18, 2018 | 10:20 PM
  #226
magnethead's Avatar
magnethead
See for yourself
Old Dec 18, 2018 | 10:23 PM
  #227
magnethead's Avatar
magnethead
Went to the track on Saturday...
Photos by Randy Curtis (Curtis Photo Art) and Ronnie Barnes (XRP TV)
I'll have more updates during the next 2 weeks. About to change a LOT of things.
Old Dec 23, 2018 | 09:37 PM
  #228
magnethead's Avatar
magnethead
I thought I had a post with part numbers for the front brake swap, but I guess not.
Donor Platform: 2003 Dodge Durango 2WD
Oreilly retail pricing
Front Left Caliper Only: 18-4877, $48.99 + $35 core
Front Left Caliper + Bracket: 18B4877, $54.99 + $42 core
Front Right Caliper Only: 18-4876, $48.99 + $35 core
Front Right Caliper + Bracket: 18B4876, $54.99 + $42 core
Front Left Brake Rotor: 780133RGS, $74.99
Front Right Brake Rotor: 780133RGS, $74.99
Brake Pads, Set: MKD966, $21.99
Left Upper Ball Joint: K7392, $92.99
Left Lower Ball Joint: K7393, $94.99
Right Upper Ball Joint: K7393, $92.99
Right Lower Ball Joint: K7393, $94.99
Price to replace everything: $281.95 for brakes + $185.98 for UBJ + $189.98 for LBJ = $657.91
It looks like O'Reilly's hates MOOG. Rockauto has the ball joints WAYYYY cheaper.
K7393 $36.99 Lower
K7392 $37.79 Upper
$281.95 + $75.58 + $73.98 = $431.51
NAPA Retail Pricing is pretty much the same:
Front Left Caliper + Bracket: CAL SE5428A, $54.99 + $27.78 core
Front Right Caliper + Bracket: CAL SE5427A, $54.99 + $27.78 core
Front Left Brake Rotor: NB 48880133, $79.99
Front Right Brake Rotor: NB 48880133, $79.99
Brake Pads, Set: TS TS7868M, $21.99
Old Dec 23, 2018 | 09:41 PM
  #229
Holy crap, the ball joints are a 100 bucks a shot???? What are they made from? Platinum????
Old Dec 23, 2018 | 10:34 PM
  #230
magnethead's Avatar
magnethead
I posted in the dakota group on FB, looks like O'Reilly and MOOG are not getting along. Rockauto has the ball joints for $37 each instead of $98 each. Just a small discrepancy, eh?
