Squealing from clutch?
Old Nov 7, 2022 | 03:20 PM
water jug's Avatar
water jug
Default Squealing from clutch?
Hey guys I’ve got a 2001 3.9 Dakota. It’s been making a pretty bad squealing noise when in idle and driving. It’s not the belt and it seams to be coming from the bottom of the engine bay. It also makes a much worse squeal when I press the clutch pedal in. The clutch seems to be working fine and I haven’t found anything regarding this issue. I’m planning on replacing the clutch but will that fix the constant squeal too? What do you guys think the problem is/ what should I do?
Old Nov 7, 2022 | 03:26 PM
Is it the same squeal? If you are sitting still, idling in neutral, do you get a different sound when you start applying pressure to the clutch, or, does the sound it's currently making change?
Sounds for all the world like a failing throwout bearing to me. It will likely work fine, right up until it fails completely. Which could be tomorrow.... or even the next five minutes.
Old Nov 7, 2022 | 03:35 PM
water jug's Avatar
water jug
It’s the same squeal that just changes when the clutch is pressed
Old Nov 7, 2022 | 07:39 PM
Throwout bearing. Replace it when you do the clutch.
