2002 Dakota No Back Up Lights
Old 11-23-2022, 12:00 PM
cl440's Avatar
cl440
cl440 is offline
Default 2002 Dakota No Back Up Lights
2002 Dakota Quad Cab 4x4 4.7 45RFE Automatic
I have a short somewhere in the reverse light circuit. It will blow the fuse every time that I drop it in reverse. Is there a schematic of the reverse light system I can look at so I can identify and trace the components to track down the short? Is there a back up light switch that may have shorted? Is there a common component in the system that causes this on Dakotas? I will tear into it and look for the short when I get time just wanted a little info to arm myself with before I do
. Thanks
Old 11-23-2022, 03:59 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,198 Likes on 2,950 Posts
Try looking here. Should be able to help ya out.
Old 11-23-2022, 04:11 PM
cl440's Avatar
cl440
cl440 is offline
That's great! Thanks I will check it out
Quick Reply: 2002 Dakota No Back Up Lights
