Missing and popping noise at exhaust.
Old May 21, 2023 | 07:32 PM
Virg23's Avatar
Virg23
Default Missing and popping noise at exhaust.
I replaced an ignition coil because it seemed to run rough and have a miss.
I did various checks to determine it was bad.
Now it is still running rough and makes a popping noise at the exhaust, while sweating out some water.
I put a cloth on the exhaust and seems like it actually sucks the cloth back in with the popping sounds.
Wondering what to look at, such as valve issue?
I can't seem to attach the video or a url on YouTube to see the video that shows what I'm talking about, so I will add the YouTube url.
https://youtu.be/6rH-w58aUns
Old May 21, 2023 | 08:20 PM
Think I would run a compression test, or leakdown test.... I would suspect a bad valve, or seat somewhere.
The video is neat. That sounds REALLY bizarre with the rag in front of the pipe.
Old May 22, 2023 | 10:17 AM
Virg23's Avatar
Virg23
Default Next test
I plan to do compression tests and also check coolant for hydrocarbons.
Old May 23, 2023 | 12:40 PM
Virg23's Avatar
Virg23
Default Found the issue
It came down to two bad coils and also took care of the issue I posted on another thread for the coolant temperature running too high, but seeming okay.
I've been idling the truck for about 45 minutes and temperature is about 1/2 way mark. Fans kicking in when triggered.
This is the updated video I put on my YouTube.
