Front Coil Spring Question
Old May 31, 2023 | 09:38 AM
Crapgame44's Avatar
Crapgame44
Default Front Coil Spring Question
Hi. I’ve got a 2002 V6 SLT with a sagging front end. It’s about 1.5 inches lower at center top of wheel wells than the rear. If I replace the old coil spring s with stock replacement springs will it even up the height with the rear that much distance? Or do I need a 2.5 inch lift spring to help ( found them online). The stock springs much cheaper. Thx for your advice
Old May 31, 2023 | 11:38 AM
Stock, the front will sit lower than the front.
Old May 31, 2023 | 01:45 PM
Crapgame44's Avatar
Crapgame44
Thx. So even with a fresh stock spring it won’t even raise even with the rear?
Old May 31, 2023 | 02:23 PM
The front was lower than the rear when it was brand new..... So just changing the springs won't make it level...... Reason behind that is, when you put a load in the bed, it squats.... having the rear lower than the front does strange things to steering geometry.
