4.7 rebuild. Crank no start.
I've been buying ECMs from autocomputerexchange for years. I usually go thru their ebay store cause their prices are better and they communicate well - also the customer support is much better thru their ebay store then thru the phone. I know they do repairs as well. You can try them. They are located in Florida FYI
Got a chance to look at the timing on this truck and started at the passenger valve cover. Popped the cover off and compared the new timing gear cam sensor ring to the old and they appear to have very different gaps between openings. Very noticable and not a maybe. Looks like the eBay rebuild kit may have screwed me on this one. Will update when changed.
Changed out the cam sensor gear and sprocket and she fired up first turn of the key. HUGE lesson learned. If you go cheap on parts make sure they are correct. Thanks for all the help!!!
