I have a 2003 Dodge Dakota 4.7L quad cab manual transmission.
I've had possible symptoms of a bad ground wire... parasitic draw and my headlights don't turn off normal (if lights are on and I turn engine off, I have to turn lights to off, back to on, then off again to turn off the lights - already tried replacing switch).
Parasitic draw traced to fuse 8 on the driver side fuse box. More info on that in the post below, never solved, just put a quick disconnect on the battery...
Looking around under the hood I found this ground that looks like there was a wire that ripped out at some point, but I can't find any loose wires hanging around that area. See images attached.
I'm hoping someone could tell me what is supposed to be connected here. It is on the passenger side of the engine underneath the windshield.
