Stuck brake pedal (2003 Dodge Dakota)
Old Feb 22, 2024 | 11:01 AM
flickit's Avatar
flickit
Default Stuck brake pedal (2003 Dodge Dakota)
A friend borrowed my truck and left it with the brake pedal stuck in the down position! Is this bound to be a brake vacuum issue or is there a return spring in the cab to bring the pedal back to the 'rest' position?
Thank you.
Flickit
Old Feb 22, 2024 | 12:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
A brake booster issue. There is no external return spring for the pedal.
Old Feb 22, 2024 | 03:28 PM
flickit's Avatar
flickit
Thank you!
Flickit
Old Apr 20, 2024 | 11:39 AM
flickit's Avatar
flickit
Default Brake issue Dodge 2003 Dakota
So we replaced the brake assist drum and the master cylinder and still the pedal stays down. My friend mentioned some electronic device that needs to be replaced that has something to do with the ABS.
Any idea what this is called and where to find it?
Thank you,
Flickit
Old Apr 20, 2024 | 11:59 AM
Nope. Won't matter. You have a mechanical issue, not an electronic issue. Check the pivot for the brake pedal.
Old Apr 20, 2024 | 05:27 PM
magnethead's Avatar
magnethead
What HeyYou said. The pedal should "float" freely. Either the pushrod is getting stuck in the booster/firewall and/or the pivot has issues.
Old Apr 20, 2024 | 06:09 PM
Dodgevity's Avatar
Dodgevity
Was your friend towing without trailer brakes, maybe? That could cause someone to stand on the brakes hard. You might be leaking brake fluid somewhere. Check the lines going everywhere and fluid level. Check up by the ABS unit too. Pull the wheels off and check the calipers. Spin the wheels while on stands, see if anything is locking up.
