Oversurges
Old Dec 26, 2024 | 08:26 PM
Jonesie53's Avatar
Jonesie53
Default Oversurges
My Dakota 4.7l is electrically overloading, I believe it is a braided ground wire from the body to ??? Can anyone help me please?
Old Dec 26, 2024 | 08:51 PM
What is it actually doing?? Is your volt meter spiking? Got wires smoking?
Old Dec 26, 2024 | 09:10 PM
Jonesie53's Avatar
Jonesie53
[QUOTE=HeyYou;3599705]What is it actually doing?? Is your volt meter spiking? Got wires smoking?[/QUOTE-yes the volt meter is spiking.
Old Dec 26, 2024 | 09:13 PM
Jonesie53's Avatar
Jonesie53
Yes the volt meter is spiking. I believe it's the ground strap from the body to ???
Old Dec 26, 2024 | 09:21 PM
Jonesie53's Avatar
Jonesie53
Old Dec 26, 2024 | 09:24 PM
Jonesie53's Avatar
Jonesie53
I believe it's the braided ground strap from body to frame that's just hanging down underneath.
Old Dec 26, 2024 | 09:40 PM
Jonesie53's Avatar
Jonesie53
Yes spiking
Old Dec 27, 2024 | 09:23 AM
Ground strap won't do that. You either have a bad alternator, or failed voltage regulator. Unfortunately, the voltage regulator is part of the PCM.....
Old Dec 27, 2024 | 09:10 PM
Jonesie53's Avatar
Jonesie53
Thanks, I was just thinking the same about that being the alternator but I thought the voltage regulator was inside the alternator. PCM is on the tranny or control box?
Old Dec 27, 2024 | 09:33 PM
Probably under the hood, on the passenger side firewall.... I think. Powertrain Control module.
