Code help
Old Apr 11, 2025 | 09:28 AM
  #51
steve05ram360's Avatar
steve05ram360
pull the connector on the coolant temp sensor & see if it stays running. it should keep it in open loop mode & may allow you to get going to move it to a different spot (near auto parts store).
Old Apr 15, 2025 | 05:45 AM
  #52
LEDshot's Avatar
LEDshot
When I am finally able to get it started, it stays running. I just has no acceleration and when I shut it down, it doesn't fire up immediately.
Old Apr 15, 2025 | 01:15 PM
  #53
steve05ram360
Originally Posted by LEDshot
When I am finally able to get it started, it stays running. I just have no acceleration and when I shut it down it doesn't fire up immediately.
check the map sensor output... if this sensor is not working correctly it could produce the symptom you have.
Old Apr 15, 2025 | 01:16 PM
  #54
LEDshot's Avatar
LEDshot
Map sensor output?
Old Apr 15, 2025 | 01:23 PM
  #55
LEDshot's Avatar
LEDshot
I can start it, I just have to play with the accelerator to the point that it's flooded. I can smell gas. It does idle and the idle is smooth-ish.
When I turn it off, it doesn't fire back up immediately, I have to play with the accelerator to get it to start.
Old Apr 15, 2025 | 09:21 PM
  #56
LEDshot's Avatar
LEDshot
So, if I leave my battery disconnected will it reset all the codes, yeah?
When I start it back up it'll set the codes that are actually affecting my truck?
Because when I put the new battery in the only codes it was throwing was the p0052.
It also throws a 0499 but it's thrown that since before I got the truck and I got the truck in 2017.
Old Apr 16, 2025 | 09:24 AM
  #57
Yep. Simply disconnecting the battery for 10 to 15 minutes should reset all the codes. I tend to disconnect the battery, and turn on the headlights, that makes sure any residual energy is dissipated, and the PCM really is reset. Turn off the headlights, hook the battery back up, see what happens.
Old Apr 17, 2025 | 07:40 PM
  #58
LEDshot's Avatar
LEDshot
Okay, I've done that. The only code that's really throwing me is the 0052 and it's done that three different times.
Old Apr 17, 2025 | 08:06 PM
  #59
That's just the heater control circuit for bank 2. That should NOT cause the driveabiity problems you are seeing.
Old Apr 18, 2025 | 01:09 PM
  #60
LEDshot's Avatar
LEDshot
So what do I need to be looking for, live data?
