Code help
Old Mar 21, 2025 | 05:40 PM
  #31
LEDshot's Avatar
LEDshot
Originally Posted by hidden1
Auto zone rents a pretty good one with all info an abs too ..try that one .it's free ..Also those lil plug in blue tooth. Cordless ones to a phone app ones work great too !
You get app an can see the trim an all including 02 readings..
8 BUCKS ON AMAZON....an 2 bucks on Walmart!..CALLED -. ELM 327. ITS BLUE ..WORKS GREAT !
Yes look under DATA STREAM reading as magnet said
I'm sitting in the Walmart parking lot at 8400 Coral Way and there I have no idea where an AutoZone would even be. Wherever I Go needs to be walking distance from here.
Old Mar 21, 2025 | 05:44 PM
  #32
LEDshot's Avatar
LEDshot
Default Update
I definitely have an electrical issue. Last night I checked my battery with a voltmeter and it told me I was at +10 volts, when I checked again this morning it was showing a bit under 8 volts. I just checked a few minutes ago and I'm still at a high 7 volts
Old Mar 21, 2025 | 07:36 PM
  #33
That's gonna be a problem..... You got a pretty significant draw there somewhere, and a dead battery will neither start, nor run, the truck...
Old Mar 21, 2025 | 08:52 PM
  #34
LEDshot's Avatar
LEDshot
Obviously,
It doesn't even have enough power to activate my scanner.
Old Mar 21, 2025 | 09:04 PM
  #35
Now what? I don't think a jump is gonna cut it.....
Old Mar 22, 2025 | 04:16 PM
  #36
LEDshot's Avatar
LEDshot
According to my scanner, the voltage of my O2 sensor bank 2 sensor 1 is 1.270 volts no fluctuation.
Old Mar 22, 2025 | 04:19 PM
  #37
LEDshot's Avatar
LEDshot
I don't have anything that says open/close loop monitor
Old Mar 22, 2025 | 05:02 PM
  #38
It's my understanding that O2 voltage should fluctuate between zero, and 1 volt on the signal return.... If it's fixed at 1.2 and change..... Does the engine actually stay running with that sensor unplugged? Does the readings on the scanner change?
Old Mar 23, 2025 | 01:45 AM
  #39
LEDshot's Avatar
LEDshot
Nope, my truck doesn't stay running with it unplugged it runs for about 3 minutes and dies. It won't start back immediately, I have to wait for a bit.​​​​​
Old Mar 23, 2025 | 09:09 AM
  #40
What's missing when it won't start?
