98’ dakota 3.9 ac problems after replacing ac compressor
Old Aug 15, 2025 | 08:19 PM
98southla's Avatar
98southla
Question? Are these trucks supposed to have 2 orifice tubes?? One on the condenser right before it connects to the high side line with the service port then another one under the air filter box? I never heard of a vehicle having 2. The only one I have in is the the line under the air filter box.
Old Aug 15, 2025 | 08:23 PM
Hhhmmm..... My Mitchell on Demand website doesn't seem to be working today..... Wonder if it got taken down.... It's a russian site though... so, no tellin'..... Worked great for years.
If you have the wiring diagram, can you post it up?
Old Aug 15, 2025 | 09:06 PM
Ok, it started working again....
If you have power across the pressure switches, see if you are getting a ground from the PCM for the A/C compressor relay.
Check fuse 7, and fuse 6 in the PDC as well.
