Radiator Drain Plug/Petcock Leak
Old Aug 23, 2025 | 04:47 PM
hewey13's Avatar
hewey13
Default Radiator Drain Plug/Petcock Leak
Hoping someone can help. I swapped my water pump this morning and when I re-installed the radiator plug and added coolant, it started leaking from the small drain below the plug.
I’ve got a picture of the issue and of the plug. I can’t seem to find a replacement plug anywhere (in store or online) or even a picture of the one I have to see if it had an o-ring that fell off.
2003 Dakota SLT 4WD, V8, 4.7L
Any help would be appreciated.
Old Aug 23, 2025 | 05:40 PM
Yes, there is supposed to be an o-ring there......
Old Aug 23, 2025 | 06:30 PM
hewey13's Avatar
hewey13
Any ideas on how I might track one down? I can’t seem to find this exact plug anywhere online.
Old Aug 23, 2025 | 08:04 PM
Look in the radiator, see if it isn't still in there, and just not in the right place. Or, look in the bucket of old coolant.
I *think* the Oring goes on the nub on the end of the plug there.... I think..... so, might go to the parts store, see if you can find something that'll fit.
Old Aug 23, 2025 | 08:09 PM
Addendum: I think your radiator has been replaced from stock.... Your drain plug doesn't look anything like the stock unit..... Totally different......
Old Aug 24, 2025 | 12:27 PM
hewey13's Avatar
hewey13
I did end up getting an assorted pack and found one that fit on the end and that sealed it right up. I couldn’t see the old o-ring inside the hole so assuming it must have been flushed out. Thanks for the suggestion!
Old Aug 24, 2025 | 12:28 PM
Hey, it worked! Awesome.
